LabWindows/CVI
How to convert string to ViChar array?
i created a wrapper for a ivi function and added to addtional parameters to it (Result and TXT).
It is working fine but how can i make the bold text working?
The "if" part works only problem in the else-path.
How can i set the string into the ViChar array?
Thanks for help
        void __declspec(dllexport) ConfigureOutputEnabled(ViSession vi,  ViInt32 index, ViBoolean enabled, ViInt32 &Result, ViChar TXT[] )
            Result = IviDCPwr_ConfigureOutputEnabled(vi, channelName, enabled);
            if (Result != 0)
                IviDCPwr_error_message(vi, Result, TXT);
            else
                //TXT[] = "No error"; //How to change this?
(4,398 Views)
If you want your dll to return the result value to the caller you should declare it as ViInt32 *Result, and use *Result in the function body.
For the string parameter, couldn't you declare it as a ViChar * and fill it with strcpy ()? I'm not using Ivi so I don't know if this is safe for IviDCPwr_error_message () function.
(4,387 Views)
There is no problem with Result parameter.
strcpy is not working here.
I solved it with this:
Copying index by index into the output array.
              ViChar temp[] = "No error.";
               for(int i = 0; i < sizeof(temp); ++i)
                       TXT[i] = temp[i];
(4,384 Views)
