LabWindows/CVI
How to change build options from Borland C/C++ to MS Visual C/C++
I've started a project with compiler/build options set for Borland C/C++. After I had the project working, I obtained the "cviinet.fp" from a colleague (which it was created using MS Visual C/C++ as the compiler option).
I'm now trying to use such fp, however, I am getting an incompatibility error because of the Borland C/C++ mode I used for my original project and MS Visual C/C++ mode used to created the fp.
How do I fix this? or how do I get around this issue?
Is it recommended to switch build options? If yes, how do I change build options for a project that has already been started and working?
(3,059 Views)
You can re-run the CVI installer to change compatibility modes. On thing to note, National Instruments sells a toolkit for CVI called Enterprise Connectivity that includes an instrument driver for internet functions called "cviinet.fp". If you are using that and received it from a colleague, you are violating the software license. If he just happened to name his custom instrument driver cviinet.fp, then there is no problem.
Best Regards,
Chris Matthews
(3,059 Views)
For clarification purposes: the "FP" I'm referring to in my question is a "custom home-made" fp.
(3,059 Views)
