LabWindows/CVI
How to Determine if an Instance of Microsoft Excel is Running?
In LabWindows/CVI, I need to determine if one or more instances of Microsoft Excel are running.  Can anybody point me to a CVI function that would do the job?
Chopper77
(3,252 Views)
I suppose the easiest wat is to try to connect to it: you could use the ActiveX command Excel_ActiveApp (you'll need to load Excel2000.fl instrument driver to use it) and see if it returns an error.
(3,238 Views)
Hi Chopper77.
If you have the Windows SDK installed, you could adapt this code from MSDN to do the job.
(3,209 Views)
