LabWindows/CVI
cancelar
Mostrando resultados para
Pesquisar então
Você quer dizer:
How do I create a directory within CVI?
How do I create a directory from within CVI?
Mensagem 1 de 12
7.339Exibições
Creates a new directory based on the specified directory name.
Note:  Only one directory can be created at a time.
/*-------------------- Prototype ---------------------*/
int MakeDir (char Directory_Name[]);
Utility Library\Diretory Utilities
Thanks.
CVI 2010
LabVIEW 2011 SP1
Vision Builder AI 2011 SP1
Mensagem 2 de 12
7.335Exibições
This seems really straight forward, but for some reason adding a call to MakeDir gives this error when I compile:
Undefined symbol '_MakeDir@4' referenced in "report.c"
However, I have included utility.h. So I'm not sure what the problem is. Also, the project is real-time only. Any ideas?
Mensagem 3 de 12
6.794Exibições
Maybe CreateDirectoryA might work (according to http://zone.ni.com/reference/en-XX/help/370051K-01/cvirtmodulehelp/windowssdkfuncsinrt/ this function should be available in RT)
For parameter definition see windows sdk help.
Mensagem 4 de 12
6.750Exibições
I found kernel32_lvrt.lib on my desktop. I couldn't find any header files. How do I go about including this library in my project?
Mensagem 5 de 12
6.748Exibições
windows.h
put it at top of your includes
Mensagem 6 de 12
6.743Exibições
Thanks, I'm having trouble finding documentation for the sdk library.
Mensagem 7 de 12
6.736Exibições
in CVI: Help/Windows SDK
What i forgot to say: you must have Windows SDK installed with CVI.
Here an extract:
BOOL CreateDirectory(
  LPCTSTR lpPathName,                         // directory name
  LPSECURITY_ATTRIBUTES lpSecurityAttributes  // SD
You can set lpSecurityAttributes to 0 for RT systems.
Mensagem 8 de 12
6.732Exibições
So am I to gather that the utility.h and/or the MakeDir method is not RT safe?  Is this why it does not work?
Mensagem 9 de 12
6.642Exibições
I don't know if it is safe or not. I only know that this function is not contained in the RT library.
Maybe a National Instruments representative can answer this question.
In the meantime you can use the SDK funktion.
... and while there is a workaround there is no need to change anything Piscadela do Smiley
Mensagem 10 de 12
6.619Exibições
