LabWindows/CVI
How do I compile LW/CVI application using winsock2 SDK from Microsoft?
I'm using CVI 5.0.1, linking with ws2_32.lib and providing the include path to the winsock2 header files. Still getting winsock2.h errors, link errors.
(6,285 Views)
I don't have problem using winsock library, but I am using CVI6.0
In my C file, the order of include files is
winodws.h
winsock2.h
Includes.h (all my CVI inlclude files)
the ....CVI\sdk\include path is added under "Include Paths" option
ws2_32.lib is added to the Project from CVI\sdk\lib folder.
Hope it helps.
vishi
"fermenter" wrote in message
news:506500000008000000B9810000-1042324653000@exchange.ni.com...
> link errors.
(6,285 Views)
Please make sure that you are using the Win32 SDK support that ships with LW/CVI. If you don't have it already installed, you can perform a custom installation and manually add the support for Win32 SDK. Once you have the support installed, you don't have to explicitly specify the directory in the include path. However, you have to add the library file in your CVI project in order to link your files correctly.
Mika Fukuchi
Application Engineer
(6,285 Views)
In my CVI 6.0 installation, i don't have W2_32.lib, from where i can get it?
(5,949 Views)
If you have the Full Development System (FDS) of CVI, then you need to rerun the installer, and when you get to the feature tree, make sure that you enable the LabWindows/CVI>>Win32 SDK feature.
If, on the hand, you have the Base version of CVI, then I'm afraid you're out of luck. These additional SDK files are one of the differences between Base and FDS.
Luis
(5,929 Views)
Thanks LuisG
   I think i have to reinstall my CVI and try again.
Vishnu
(5,879 Views)
