LabWindows/CVI
How do I communicate with a USB device using Labwindows 6.0?
Hi all,
I am kind of new to programming, but was given the task of communicating with a USB device using Labwindows 6.0, but the current code is for serial communication. I was able to get my USB device connected and showing up as a Visa, but I have no clue what to do next. Thanks for the help.
Message 1 of 8
(5,610 Views)
If you see your device as a VISA resource, then you can use alla the VISA functions (see Library >> VISA to browse into the complete list).
With this functions you can read, write, flush the buffers, list the devices, ...
As a starting point you can substitute all the old serial functions with the VISA ones.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
Message 2 of 8
(5,599 Views)
Ok, I can get the device to work in VISA Interactive Control, but not using the libraries or sampel code I found. I keep getting an error for the instrument descriptor which I am copying from NI-VISA as USB0::0x10C4::0xEA60::0001::RAW. The error is an undeclared indentifier.
Message 3 of 8
(5,585 Views)
This is the sample code I am using:
#include "visa.h"
int main(void)
ViStatus status;
ViSession defaultRM, instr;
/* Open Default RM */
status = viOpenDefaultRM(&defaultRM);
if (status < VI_SUCCESS) {
/* Error Initializing VISA...exiting */
return -1;
/* Access other resources */
status = viOpen(defaultRM, USB0::0x10C4::0xEA60::0001::RAW, VI_NULL, VI_NULL, &instr);
/* Use device and eventually close it. */
viClose(instr);
viClose(defaultRM);
return 0;
Message 4 of 8
(5,584 Views)
Oh I think I got it, I forgot the "" around the call. But I am sure more questions will follow 🙂
Message 5 of 8
(5,582 Views)
Does anyone have concrete examples for communication? I can open and close a session, but I cannot even get the device's manufacturer name without errors or timeouts.
Message 6 of 8
(5,560 Views)
Concrete examples depend on devices...
This tutorial is a really useful starting point: I would suggest you this steps
  1. try to successfully communicate with your device using VISA through MAX
  2. try to give the same commands through CVI
Vix
Using LV from 7
Message 7 of 8
(5,544 Views)
Hi!
I've attached an example that I downloaded from NI and modified to work with
my Tektronix TDS2024B digital scope via USB port.  The original code was written
to use GPIB connection for the instrumental control.  As you can see in the code,
I simply change the device ID from "GPIB::11::INSTR" to
"USB0::0x0699::0x036A::C034102::INSTR" as it is assigned in the NI-MAX.
Works seamlessly in LabWindows 6.0, but you do need to install NI VISA 4.2 and
NI IVI Compliance Package 3.1 first.  Hope this example help!
Message 8 of 8
(5,459 Views)
