LabWindows/CVI
How code smallest number EPS?
I am compiling C-code using LabWindows/CVI for use as a shared library in LabVIEW on a PXI real-time target. In my C-code, I need to initialize some variables with a very small number to avoid divide by zero problems.
Is there a constant defined in one of the header files referenced by ansi_c.h that I can use? It is usually referred to as EPS, but that doesn't seem to be recognized by the compiler.
Thanks in advance,
Frenk
(3,370 Views)
Hello
You might be looking for DBL_EPSILON or FLT_EPSILON ,which is defined as smallest x so 1.0 + x != 1.0
You will need to include float.h for this. Check out this link for more info.
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,370 Views)
Great!
Thank you,
Frenk
(3,370 Views)
FYI,
Here is some cool code that calculates EPS and some other special characters of doubles.
Enjoy,
Juan Carlos
N.I.
(3,370 Views)
