‎12-04-2005 07:43 AM
‎12-07-2005 02:40 PM
Try configuring you Access database as a System DSN.
What is your error code?
If it still does not work, attach you database along with code and I will try it.
robskii
‎12-08-2005 03:46 AM
Thank you for your reply.
I'll check what is an error code and I'll back with reply tomorrow.
‎12-08-2005 09:33 AM
I would make sure that the Microsoft Jet drivers are also atleast on version 3. Prior to that, I don't think the Jet drivers were multithreaded. This might be your problem. But your system would have to be way out of date...
Orlan
‎12-22-2005 05:47 AM
