LabWindows/CVI
Help using ConnectToTCPServer function for connecting to a printer
I am attempting to communicate to a printer using the following function:
int ConnectToTCPServer (unsigned int *conversationHandle, unsigned int portNumber, char serverHostName[], tcpFuncPtr callbackFunction, void *callbackData, unsigned int timeOut);
For the serverHostName, I am using the IP address of the printer. However, I am confused as to what number to put for the port number. How do I obtain this information?
Thanks!
(3,065 Views)
Accepted by mjeddi
If the printer has a TCP server, the port to use is normally listed into the printer documentation.
(3,046 Views)
Thanks I found it!
(3,041 Views)
