LabWindows/CVI
Help Suport : CANoe 6.1 Library
I am useing LabWindows/CVI with CANoe 6.1 Type Library.
I want to access remotly CANoe Tool, from my local machine. Now, I am able to open/close CANoe, load a config file, start a measurement, but the CANoe_IMeasurementStop function returns -2147352567,and it dosen't stop the measurement. Do you know why?
So, if anyone have some examples :  - Access a defined Panel from CANoe, loaded with a specific cfg file.
                                                             - Send a message to CAN network
                                                             - Activate a specific CAPL script... etc
or any kind of help support, documentations for this Library
     it will be very helpful for me.
Thank you.
Lucian.Corduneanu@hella.com
(3,453 Views)
Hey Lucian,
It sounds like you are using an ActiveX server and making calls into it.  Do you have a manual that came with your CANoe (or CANcard) hardware or software?  Their documentation should allow us to figure out how to make calls correctly into this ActiveX server.  Also, the error code that you provided looks like an ActiveX error code that we could hopefully look up in that documentation.  I hope this helps.
Best Regards,
Software Engineer
Jett R
(3,421 Views)
