 TucsonJB
			TucsonJB
			09-24-2015 10:45 AM
Hello everyone, The foroums has several unanswered posts about this topic and I was wondering if anyone has had any success using it? I am trying to get the example to work, but am receiving a error code -4 System Socket Error. I don't know if this is because my mail server is not using port 25. Does InetSenrMail require a server on port 25? I have tried using the Telnet tests and can't even find a server using port 25. Anyone's help who has experience with this would help. Thanks.
 Jattie
			Jattie
			09-28-2015 05:36 AM
Sending mail from any application or test script is unfortunately never straight forward as one might imagine. The majority of times your mail gets blocked by local PC or or IT imposed network constraints.
So your first point of failure is antivius products blocking your PC from sending the message.
Your second point of failure is the IT policies not allowing you access to the port you try to open.
The third is the mail server blocking you access.
the easiest way to resolve your issues using the tools and opening the required ports and permissions is from a telnet session. On windows 7 and later Telnet is disabled by default and needs to be enable first. (https://kb.ctera.com/article/how-to-open-a-telnet-session-on-windows-7-or-windows-8-os-16.html)
After you enabled telnet open a telnet session and connect to the mail server you want to send mail messages through and issue commands and observer responses and errer messages. This will get you to the bottom of the failure and ports and services opened and enabled to allow you to send mail.
See this article on using telnet to send mail from the commandline: https://technet.microsoft.com/en-us/library/aa995718(v=exchg.65).aspx
Best regards
