‎11-09-2005 02:56 AM
‎11-10-2005 09:24 AM
NI-IMAQ installs examples to work with CVI, so under:
C:\Program Files\National Instruments\CVI71\samples\IMAQ\Grab
you can use directly HLgrab.prj that performs a grab acquisition.
If you don't have these examples then you have to modify the ni-imaq installation and add the support for CVI.
Best Regards
AmbuA
‎11-10-2005 09:47 AM
‎11-11-2005 08:44 AM
are you able to perform a grab acquisition from Measurement & Automation (MAX)?
Here there is a link that explains how test your board under MAX.
http://www.ni.com/support/imaq/
If you aren't able to grab in MAX probably there is an installation issue or you camera doesn't submit the standard.
Best regards
AmbuA
‎11-11-2005 09:20 AM
‎01-13-2006 03:00 AM
‎01-13-2006 03:03 AM
