LabWindows/CVI
GetMonitorAttribute Bug
Hello All
I am having an issue with the GetMonitorAttribute function. I am using a dual monitor set up for a test station, and the second monitor will be unplugged and pluged back in quite often. The first go around the call to GetMonitorAttribute works fine. If I unplug the hdmi cable and plug it back in, the data retrived from the function is garbage. I am running LabWindows 2013 f1.
Apparently this was a bug in 2012 (See ID 397059):
https://www.ni.com/en/support/documentation/bugs/13/labwindows--cvi--2013-bug-fixes.html
Any ideas?
Thanks!
(5,914 Views)
Hi bry0n,
The bug you pointed out is specifically for the GetMonitorFromPoint, GetMonitorFromRect, and GetMonitorFromPanel functions, so a bug in GetMonitorAttribute may not have been fixed. To report a bug we need steps and a small set of code to reproduce this issue. Could you post those here? We can take a look at it and determine if a new bug report needs to be filed.
Kevin Flanagan
(5,847 Views)
Hi Kevin,
Thanks for the reply. I did not realize the bug I found was for those other functions.
Here is a snippet of code that I am using:
GetSystemAttribute (ATTR_PRIMARY_MONITOR, &primaryMonitorID);		//Find Primary monitor
GetSystemAttribute (ATTR_NUM_MONITORS, &numMonitors); 			//Get the number of monitors
if(numMonitors > 1)							//As long as there is more than one monitor
	for(loop = 1; loop <= numMonitors; loop++)					//Begin a loop through the monitors
		GetMonitorAttribute(loop, ATTR_WIDTH, &width);			//Get the monitor width
		GetMonitorAttribute(loop, ATTR_HEIGHT, &height);		//Get the monitor height
		GetMonitorAttribute(loop, ATTR_LEFT, &posLeft);			//Get the x origin (top left of screen)
		GetMonitorAttribute(loop, ATTR_TOP, &posTop);			//Get the y origin (top left of screen)
		if( (numMonitors >= 1) && (width == 1280) && (height == 800) ) //Look for specific monitor size
			SetPanelSize(panelLcdHandle, height, width);           //Set the panel to fit monitor
			SetPanelPos(panelLcdHandle, posTop, posLeft);          //Set panel onto screen
			break;
The code works fine the first time through, but if the monitor is unplugged and plugged back in is when the issue arrises.
(5,829 Views)
Thanks for the code, I'm going to attempt to reproduce this on my system and file a bug report if necessary.
Kevin Flanagan
(5,801 Views)
Any luck with this?
(5,517 Views)
Has this problem been addressed? I am having the exact same issue on Labwindows/CVI 2013.
(3,970 Views)
Hi vicgd,
I am sorry that you are experiencing this issue. The LabWindows/CVI development team has run into some obstacles regarding this issue in software version 2013. The behavior has been fixed in CVI 2015.
Best Regards,
Mitchell Faltin
(3,954 Views)
