07-21-2015
01:29 PM
- last edited on
11-18-2024
11:57 AM
by
Content Cleaner
Hello All
I am having an issue with the GetMonitorAttribute function. I am using a dual monitor set up for a test station, and the second monitor will be unplugged and pluged back in quite often. The first go around the call to GetMonitorAttribute works fine. If I unplug the hdmi cable and plug it back in, the data retrived from the function is garbage. I am running LabWindows 2013 f1.
Apparently this was a bug in 2012 (See ID 397059):
https://www.ni.com/en/support/documentation/bugs/13/labwindows--cvi--2013-bug-fixes.html
Any ideas?
Thanks!
07-22-2015 11:23 AM
Hi bry0n,
The bug you pointed out is specifically for the GetMonitorFromPoint, GetMonitorFromRect, and GetMonitorFromPanel functions, so a bug in GetMonitorAttribute may not have been fixed. To report a bug we need steps and a small set of code to reproduce this issue. Could you post those here? We can take a look at it and determine if a new bug report needs to be filed.
Kevin Flanagan
Applications Engineer
07-23-2015 09:30 AM
Hi Kevin,
Thanks for the reply. I did not realize the bug I found was for those other functions.
Here is a snippet of code that I am using:
GetSystemAttribute (ATTR_PRIMARY_MONITOR, &primaryMonitorID); //Find Primary monitor
GetSystemAttribute (ATTR_NUM_MONITORS, &numMonitors); //Get the number of monitors
if(numMonitors > 1) //As long as there is more than one monitor
for(loop = 1; loop <= numMonitors; loop++) //Begin a loop through the monitors
GetMonitorAttribute(loop, ATTR_WIDTH, &width); //Get the monitor width
GetMonitorAttribute(loop, ATTR_HEIGHT, &height); //Get the monitor height
GetMonitorAttribute(loop, ATTR_LEFT, &posLeft); //Get the x origin (top left of screen)
GetMonitorAttribute(loop, ATTR_TOP, &posTop); //Get the y origin (top left of screen)
if( (numMonitors >= 1) && (width == 1280) && (height == 800) ) //Look for specific monitor size
SetPanelSize(panelLcdHandle, height, width); //Set the panel to fit monitor
SetPanelPos(panelLcdHandle, posTop, posLeft); //Set panel onto screen
break;
The code works fine the first time through, but if the monitor is unplugged and plugged back in is when the issue arrises.
07-24-2015 02:08 PM
Thanks for the code, I'm going to attempt to reproduce this on my system and file a bug report if necessary.
Kevin Flanagan
09-24-2015 12:40 PM
Any luck with this?
02-28-2017 10:52 AM
Has this problem been addressed? I am having the exact same issue on Labwindows/CVI 2013.
03-01-2017
01:06 PM
- last edited on
11-18-2024
11:58 AM
by
Content Cleaner
Hi vicgd,
I am sorry that you are experiencing this issue. The LabWindows/CVI development team has run into some obstacles regarding this issue in software version 2013. The behavior has been fixed in CVI 2015.
Best Regards,
Mitchell Faltin
