04-24-2017 05:33 AM
I've just migrated to Creators Update, and any application fails when exiting with a "General protection fault" message.
I'm using CVI 2015 SP1f1 and I confirmed the issue on different computers using NI sample projects.
Has anyone an idea on how to solve/avoid this issue ?
Regards.
04-25-2017 08:25 AM
I have the same problem. The CVI applications works fine but they exit with a "General protection fault" message.
There's no problem with an "old" Windows version.
04-26-2017 10:37 AM
How exactly did you reproduce this? I'm trying to cause it so I can look into it.
I'm using windows build 15063 and a fresh install of CVI 2015 SP1 f1, but see no errors on shutdown of built examples.
Trent
04-27-2017 02:20 AM
The PC is a new one, freshly updated with the last version of windows 10.
CVI was not already installed when the creators update was pushed. I use a distribution kit for installing my application.
This application works fine but crashed on shutdown.
I tried with another applications and the same problem appears. All these applications works fine with an earlier windows version.
Alain
04-27-2017 03:14 AM
On my computer:
- CVI 2013 (base) was installed at the time of Windows 7.
- Windows 7 was migrated to Windows 10 on July 2016.
- CVI 2013 has been migrated to CVI 2015 shortly after.
- RTE updated to 2015 SP1 f1
- Windows 10 Anniversary Update has been skipped, and Creators Update was done few days ago.
I'm not sure all this information is relevant, but who knows...
04-27-2017 03:18 AM
I forgot to mention that I have used "CVI2015/samples/rs232/serial.prj" but I guess any other project is triggering the bug on my computer.
04-27-2017 04:06 AM
Yes, I confirm. Same problem with a simple "hello world" program !
Alain
04-27-2017 09:02 AM
Could this be a case those who skipped the Anniversary Update discovering this issue?
04-27-2017
09:41 AM
- last edited on
11-18-2024
11:53 AM
by
Content Cleaner
Alain,
Are you positive that you're including the 2015 SP1 f1 runtime with your distribution? There were two f1 patches for CVI 2015 SP1, runtime and ADE - you need the runtime one.
You will get a crash on shutdown in Windows 10 with the non-patched runtime. So far I still haven't found any issues with the patched version on this newer windows update.
Trent
04-27-2017 10:33 AM
Trent,
I'm confused. I hadn't installed the f1 runtime patche. I did it when I saw the Ian W message and it works fine now !
Thank you very much.
Alain
