LabWindows/CVI
Function Panels.
Is there any code to open the function panels for an instrument?  I can create UIR files to emulate the function panels.
Then use LoadPanel.  However, this only works for UIR files.
The .fp panel already has what I need.  So if this can be done let me know.
(3,289 Views)
Gets,
i am sorry that i have to confess that i do not understand your question. At least not the point of it....
Well, here are some infos on instrument drivers/applications:
- An instrument driver is a library of functions for certain interactions like VISA communications (this would be the VISA-intrument driver then).
- The .fp-file is a "tool" you can use during application developement to speed up your developement time or at least protects you from misspelling variables/constants if you use the select-tools.
- The instrument driver is not meant to be used as an interface for the customer using YOUR application.
If you want to create such an instrument driver on your own, you can take a look here.
Norbert B.
NI Germany
Norbert
Expert: Geometry
(3,255 Views)
The answer was one that was expected.  The .fp files are for developement use only.
Thank you,
(3,228 Views)
