LabWindows/CVI
Full Feature operator interface
Initializing the array to 0 will no longer make it empty. You will need to specify the size of the array before you can initialize it. If your applications needs an empty array, then you should not initialize it.
Hope that helps.
Rohama K.
Message 11 of 11
(723 Views)
