LabWindows/CVI
Fortran like - variable length format strings in CVI
I have a boat load of variable length format strings from some old fortran code and it needs to be converted to CVI.  Here is an example
Digits = 6
Decimal = 4
Temp = 34.654321
Write (*100) temp
100 format(  "The temp is" F6.2 )
I want to print a F6.2 format once and then latter print the same number as a F6.4.   How would you do this?
thanks .
the old vax guy
(2,892 Views)
1st of all, I don't speak Fortran, so it can be that I misunderstand your question!
In regular C, the printf formating would be:
- printf("The temp is %6.2f\n",temp) to have 4 digit before the decimal point and 2 digit after.
- printf("The temp is %6.4f\n",temp) to have 2 digit before the decimal point and 4 digit after.
See for example: Kernighan & Ritchie, The C  programming language (2nd edition), page 13.
Regards
(2,876 Views)
