LabWindows/CVI
FileSelectPopup "Wrong Concurreny" Error
Hi All,
 I just upgraded CVI from 2013 to 2019 and now I get error -180 (UIEFileDialogWrongConcurrencyModel) when using the FileSelectPopup(Ex) function. I am using 32-bit CVI 2019  on a 64-bit Win 8.1 machine. Before the CVI (and drivers) upgrade everything worked fine. The popup function is called from my main thread. I use various threads for data acquisition and analysis (via CmtScheduleThreadPoolFunction and PostDeferredCallToThread and such), but (to the best of my knowledge) I am not using any ActiveX functions. Any hints for troubleshooting?
  Martin
(3,809 Views)
I did some more testing and it seems that when I disable all of my device functions that are based on an IVI library the popups seem to work. So as far as I can tell calling a device driver that was created using the IVI driver wizard switches the thread mode to MTA. If I lock in the thread model using
CA_InitActiveXThreadStyleForCurrentThread (0, COINIT_APARTMENTTHREADED);
in main(), the popups seem to work. So far the rest of my programs still seems to work, but I do wonder what other consequence locking the thread model has (I assume this gets switched by the IVI functions for a reason).
Cheers,
  Martin
(3,745 Views)
Has this had any adverse results?  I am having the same problems within my application and changed the FileSelectPopup( ) to MultiFileSelectPopup( ), which I only capture the first file selected.
(3,656 Views)
So far I haven't seen any adverse effects. All my functions in other threads and my thread-safe queues seem to work as they did before. I still don't know why the thread model in the new version got switched in the first place.
(3,646 Views)
