LabWindows/CVI
FileSelectPopup not outputting correct selectionStatus
When I select a file using FileSelectPopup (whether a new file or the existing file) it always outputs 1. According to the documentation it's supposed to output a 2 if you select a new file. Does anyone know what might be going on here?
(977 Views)
Can you post your code? FileSelectPopup behaviour depends also on Button label value, but it nevertheless should always return a correct value:
  • With Load and Select you can only point to existing files and it correctly always returns 1
  • With Save and Ok you can treat new or existing files and it returns 1 or 2 accordinglyt
(942 Views)
Okay, this makes more sense. I had tried multiple button label values, but my confusion seems to have been with the terminology of "new" and "existing" file. I thought the function was referring to the previously selected file vs. the new file selected (i.e. if you select the same file as before you would get 1 as the output and if you select a different file you would get 2).
Thank you so much @RobertoBozzlo, your answer really helped to clarify things!
(933 Views)
