LabWindows/CVI
File browse control function panel
How to create a file browse control on function panel? Data type for file path is char*. By dropping a input it does not provide with the browse button.
(3,672 Views)
Hi sonotk,
You can create a command button and have its callback function call the FileSelectPopup function.
Humphrey H.
Applications Engineer
(3,616 Views)
This help topic describes how to add the ... button on the function panel and associate a callback to it.
You could start from the example from samples\functionpanels\Customization\SelectColor.cws and write a function like this:
int DLLEXPORT CVICALLBACK SlectPath (FPCustomInfo *info)
    char path[MAX_PATHNAME_LEN];
    int parameter;
    FPCustom_GetSelectedParameter (info, &parameter);
    FileSelectPopupEx ("", "*.*", "", "select file", VAL_OK_BUTTON, 0, 0, path);
    /* additional processing to convert path into a string literal - enclose in quotes and
    replace special characters like '\' into escape sequences */
    FPCustom_SetParamValue (info, parameter, path);
    return 0;
(3,582 Views)
Thanks for the response. Looked at the help topic it requires a DLL to customize the function panel. I do not have DLL, its an exe. Any sugestion as to what can be selected for dll, or are the funciton panel customized only when using DLL.
(3,537 Views)
You have to create a dll which exports the function you use in the callback. This dll is only for use in the function panel, it is independent from any other program you are developing.
(3,527 Views)
