10-20-2015 01:30 AM
FATAL RUN-TIME ERROR: Unknown source position, thread id 0x000009C8: A non-debuggable thread caused a 'General Protection' fault at address 0x00A6C83D. No source line information is available. I get this error in CVI Labwindows 2015 , can any one help me in sorting out.
Thanks.
10-20-2015 02:05 AM
Maybe this post can help you.
10-20-2015 06:09 AM
Thank you, but I did all the things which mentioned in the post but still I am getting the error .Do i need to do any additional settings for CVI 2015 coz the same code runs in CVI 2005 and 2010.
01-06-2016 03:18 PM - edited 01-06-2016 03:27 PM
Hi All,
I am also getting the fatal run time error when i hit the Quit button in the application for 'map_demo'.
This is happening when the compiler is executing the closing brace (line 4) of the main function as shown in the below example.
1. void main()
2. {
3.
4. } <===
On line 4, the error is displayed as shown below.
"FATAL RUN-TIME ERROR: Unknown source position, thread id 0x000130E0: A non-debuggable thread caused a 'Unknown' fault at address 0x7744D9C7. No source line information is available."
The version number of cvirte.dll (C:\Windows\System32) is 13.0.1.201 and size is 7.20 MB
Also, Attaching the source code (map.zip) for reference.
Did anyone face this issue in Labwindows/CVI 2013 .
If so, please share your ideas so that i can safely exit from the application.
Kiran
01-12-2016 03:35 PM
Same for me. I think it started when I updated to Windows 10.
What is your OS?
01-13-2016 02:59 PM
Hi danaxe,
The OS version is Windows 7 Professional Service Pack 1
Any thoughts on this issue will be really helpful.
Kira
07-28-2016 01:43 PM
I am having the same problem under Windows 10: when using debug64, every program throws this error at exit. Has this problem already been solved?
11-05-2016 10:14 PM
I started running into this exact same problem when I upgraded from Windows 7 to WIndows 10. Fatal Run-time error everytime a program terminated. For me it was also happening in x86 debug and release.
What solved it was running a repair install of CVI 2015. I think during the Windows 10 upgrade process something got out of sync and CVI just needed to be reinstalled.
12-16-2016 06:21 AM
Yesterday there was an update on my Win10 development system, and now I have this problem. I did reboot, repair, reboot, but it's still there. Even an empty void main {;} will crash on exit.
12-22-2016 04:38 AM
I see that today's CVI patch took care of that and the error is now gone. Thanks.
