LabWindows/CVI
Extraneous formal parameter specification using RegisterTCPServerEx
I am trying to start programming an ethernet connection to control a motor drive,
and I am at the beginning of my application, so I started  by using RegisterTCPServerEx function but I already get the error "Extraneous formal parameter specification, and I don't know what it mean
\Thanks\
Olivier
(4,097 Views)
Could you post the code you developped for you application ?
Moreover, did you try using the Client / Server example ? It is available in the Example Finder under "TCP" search.
(4,065 Views)
I found the problem,
it was just because I used that function in another file and didnt write well function prototype.
Thanks anyway
Olivier
(4,047 Views)
