LabWindows/CVI
DiscardPanel from other thread
I need to Discard a panel from another thread than the creator thread.
Is there a possibility to do that ?
thank you
(3,499 Views)
The safer mode is to use PostDeferredCallToThread to permit discarding the panel in the same thread where it was loaded. If the panel was loaded in the main thread, you can simply use PostDeferredCall that implicitly calls a function in the main thread.
(3,494 Views)
thank you.
(3,487 Views)
