Export Target settings for DLL
Highlighted
i want to build a dll where i included "nimaqmx.h". Target setting is "Export what: Symbols marked for export". In the source code i declared that the functions in nidaqmx.h should not be exported by:
#undef DllExport
#define DllExport
#include
But nevertheless all the functions are exported to the dll. In the meantime I solved this by setting the export setting to "include file symbols", but this isn't the intended behaviour, is it?
1 REPLY 1
Shiner
Member
Re: Export Target settings for DLL
Firstly, did you mean...
#undef DllExport
#include
#define DllExport
Another solution would be to have a seperate header file containing only the exported functions in your DLL. Then if you ever gave that DLL to someone, you'd have a handy header file with all the function declarations within it to make life easier for them.
Chris
