02-05-2009 01:29 AM
It my understanding that this may due to running Vista 64bit, and/or related to LabWindows/CVI drivers?
I'm running LV 8.6 development suite: NI LabWindows/CVI 8.1.1 Run-Time Engine. Any input would be appreciated.
Event: 1060 Source: Application Popup
\SystemRoot\SysWow64\Drivers\cvintdrv.SYS has been blocked from loading due to incompatibility with this system. Please contact your software vendor for a compatible version of the driver.
EventData
000000000200300000000000240400C0000000006B0300C000000000000000000000000000000000 Binary data:
In Words
0000: 00000000 00300002 00000000 C0000424
0008: 00000000 C000036B 00000000 00000000
0010: 00000000 00000000In Bytes
0000: 00 00 00 00 02 00 30 00 ......0.
0008: 00 00 00 00 24 04 00 C0 ....$..À
0010: 00 00 00 00 6B 03 00 C0 ....k..À
0018: 00 00 00 00 00 00 00 00 ........
0020: 00 00 00 00 00 00 00 00 ........
Event: 7000 Source: Service Control Manager Eventlog Provider
The cvintdrv service failed to start due to the following error: This driver has been blocked from loading
EventData
param1 cvintdrv
param2 %%1275
02-06-2009 10:20 AM
Hi ewtotem,
That is correct, the reason you are seeing these errors is because this file (cvintdrv.sys) is a driver file used for low-level communications for Windows NT systems. In later versions of the CVI Run-Time Engine (RTE), this file does not get installed on Vista 64bit because the file is not compatible.
You can update your RTE to the latest version (CVI 9.0). The later version of the RTE will be compatible with anything you have written in previous versions of CVI. For good measure, you should uninstall your older version of the CVI RTE and make sure that the cvintdrv.sys file got removed before installing CVI RTE 9.0
02-06-2009 11:28 AM - edited 02-06-2009 11:29 AM
10-17-2013 09:24 AM
I have a similar issue. In the event log I have errors associated with the following:
Event 7000: The cvintdrv service failed due to the following error: This driver has been blocked from loading.
Event 1060: \SystemRoot\SysWow64\Drivers\cvintdrv.SYS has been blocked from loading due to incompatibility with thin system.
I've read a few posts and even looked into the link above, however the system I'm using has Windows 7 64 bit OS. So is there a different driver or path that works with Windows 7? Or do I just need to uninstall the incompatible driver? Thanks in advance.
