LabWindows/CVI
Ethernet/IP
I would like to communicate with a servo-motor using Ethernet Industrial Protocol (this does not correspond to TCP/IP, but TCP/IP is included in Ethernet/IP).
I found some drivers on National Instrument website (NI-Industrial Communications for Ethernet/IP Software for LabVIEW, https://www.ni.com/en-us/shop/product/ni-industrial-communications-for-ethernet-ip.html), but the library in only available in LabVIEW. I would like to find - or create - exactly the same library, with same functions (EthernetIP CIP Get/Set Attribute Single for example), but usable with Labwindows. Would you know any solution to do that properly ?
Thanks for helping me,
Danaé
(3,311 Views)
Hi Danaé,
Yo should be able to use any industry standard library. This forum thread already answers your question I believe :
https://forums.ni.com/t5/LabWindows-CVI/Ethernet-IP-in-LabWindows/m-p/2488142
Junior
(3,282 Views)
