LabWindows/CVI
Error when trying to migrate project from labwindows 2010 SP1 over to VS2008
I'm sure I've been successful back with this when running CVI 8.5 and VS2003 / 2005, but I keep gettin the following error when trying to do this with my current configuration. What am I missing?
See attached image
Regards
Gavin
(3,174 Views)
Hi umquat,
This error is pointing to a corrupt Dll in your install, have you tried a repair or reinstall of the CVI runtime engine on your computer?
Best regards
Matt Surridge
(3,148 Views)
Not recently, but what I would say is that CVI 2010 SP1 was installed after my VS2008 installation, so it ought to be in the right order.... When I get a moment I'll reinstall the CVI runtime and see what happens. Its not critical that I get this fixed, as the project in question is so small, and as the important parts are almost competely ANSI C, it should be really easy to reconstruct in C# anyway. I'll let you know what happens anyway
(3,146 Views)
