LabWindows/CVI
Error message"Data Type is not ActiveX automation compatiiable" appears when creating ActiveX controller driver in LabWindows/CVI
I use VS's ActiveQtServer to develop ActiveX controls. The compiler uses msvc2015 (32-bit). After the dll is generated and registered successfully, and the ActiveX control is successfully added in LabWindows/CVI, but when I right-click the menu "Create ActiveX Controller Driver", error message"Data Type is not ActiveX automation compatible" appears. I don't know how to solve it.
Message 1 of 1
(974 Views)
