LabWindows/CVI
Error code -94
Hi all!
I've finished my project on cvi 2015 (15.0.0.0) and made a distribution kit.
after installing it on my own computer I received the following message:
"Error in call to LoadPanelAnsi.
Parent Panel Handle: 0
UIR File Name: ****.uir
Panel Resource ID: 1
Error Code:  -94
File Not Found"
I was looking for an answer everywhere and I'm completely helpless
(3,018 Views)
Accepted by topic author CVI_Rookie
It seems the program is looking for a .UIR file and doesn't find it: have you added the .UIR file to the distribution kit?
(2,997 Views)
Thank you for your reply
Apparently, the .uir file was not included in the distribution kit. the funny thing is that I couldn't add it normally when I edit the "files" tab in the "edit installer" unless I actually drag the .uir file from the original folder.
anyway, seems to be working!
(2,963 Views)
