LabWindows/CVI
Error code -94
Hi all!
I've finished my project on cvi 2015 (15.0.0.0) and made a distribution kit.
after installing it on my own computer I received the following message:
"Error in call to LoadPanelAnsi.
Parent Panel Handle: 0
UIR File Name: ****.uir
Panel Resource ID: 1
Error Code:  -94
File Not Found"
I was looking for an answer everywhere and I'm completely helpless
(3,052 Views)
Accepted by CVI_Rookie
It seems the program is looking for a .UIR file and doesn't find it: have you added the .UIR file to the distribution kit?
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
(3,031 Views)
Thank you for your reply
Apparently, the .uir file was not included in the distribution kit. the funny thing is that I couldn't add it normally when I edit the "files" tab in the "edit installer" unless I actually drag the .uir file from the original folder.
anyway, seems to be working!
(2,997 Views)
