02-22-2012 09:11 AM
Colleagues,
After installing CVI (latest actual version) I've got strange message in Microsoft Visual Studio 2005 (appeared every time when I build solution, for example, by pressing Ctrl+Shift+B):
I don't need any integration with CVI in Visual Studio - but where can I turn OFF this (without uninstalling CVI, of course)?
Unable to found this in Preferences... ![]()
Andrey.
Solved! Go to Solution.
02-22-2012 10:02 AM
Hello -
To remove the Visual Studio integration, you should go through Add/Remove programs. In Add/Remove programs, select National Instruments software, and then Uninstall/Change. In the subsequent "National Instruments Software" dialog that displays, pick your latest version of LabWindows/CVI and select Modify:
The LabWindows/CVI installer dialog will then display. Once it does, pick the Visual Studio 2005 Wizards, and select remove:
Sorry for the inconvenience - let me know if this does not resolve things for you.
NickB
02-22-2012 10:49 AM
Thanks, Nick,
Removed this one, and the problem goes away:
