LabWindows/CVI
Error Message in Visual Studio after installing CVI
Colleagues,
After installing CVI (latest actual version) I've got strange message in Microsoft Visual Studio 2005 (appeared every time when I build solution, for example, by pressing Ctrl+Shift+B):
I don't need any integration with CVI in Visual Studio - but where can I turn OFF this (without uninstalling CVI, of course)?
Unable to found this in Preferences... Smiley Sad
Andrey.
(3,370 Views)
Accepted by Andrey_Dmitriev
Hello -
To remove the Visual Studio integration, you should go through Add/Remove programs.  In Add/Remove programs, select National Instruments software, and then Uninstall/Change.  In the subsequent "National Instruments Software" dialog that displays, pick your latest version of LabWindows/CVI and select Modify:
The LabWindows/CVI installer dialog will then display.  Once it does, pick the Visual Studio 2005 Wizards, and select remove:
Sorry for the inconvenience - let me know if this does not resolve things for you.
NickB
(3,363 Views)
Thanks, Nick,
Removed this one, and the problem goes away:
(3,358 Views)
