LabWindows/CVI
Error 1304: Error writing to file and verify that you have access to that directory
I would like to install the Labwindows CVI in NI cDAQ-9133 and some errors occur, for example, it lacks DAQmxIOctrl.fp or verify that you have access to that directory. So I tried to reinstall the NI-DAQmx. And there are still some errors as the attached picture shown.
Could anyone help to solve this problem? Thanks in advance.
(5,005 Views)
Your second screenshot shows the NI ELVISmx 17.0 installer, not LabWindows or NI-DAQmx. The ELVISmx 17.0 installer however includes NI-DAQmx 17.0, so there should not be a need for installing it manually (But is was a good troubleshooting idea).
What exactly are you trying to install, where, in which order? What LabWindows/CVI installer are you using?
And of course, have you verified that you actually have access to the path the installer complains about?
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
(4,975 Views)
Accepted by tangtangdn
Thank you, Ikaiser. I used to try to install NI-DAQmx, but similar errors occurred. I reinstalled the operating system for 9133 and it works now. Thank you for your kind reply.
(4,973 Views)
Hello tangtangdn,
Thank you for reporting back, this might help others as well!
CLADMSD
(4,958 Views)
