08-19-2009 08:28 PM
08-20-2009 01:37 AM
i am sorry, i found a lot on the net about EPICS, but i don't see what is an EPICS "handler". can you explain it here ?
i found the sources for EPICS here which can be compiled using GCC, but something tells me it may not be what you are looking for.
08-21-2009 09:18 AM
Could you please provide more information on what an EPICS handler is or links to resources on it and/or how to implement one. I am also unfamiliar with this term.
Steven Zittrower
Applications Engineer
08-26-2009 04:54 PM
Probably poor word choice by me.
I had thought that a supervisory "handler"
could be setup to execute a minimal subset of
EPICS core programs, ie CA and archiving, based on
a read of interrupt vectors and an associated data packet.
I had thought that an entry level support for EPICS might start
with at a minimal level and allow evolution using callback and
signal/interrupt processing.
11-06-2014 06:17 AM
I know this discussion is old and went nowhere, but as I'm embarking on an EPICS project, I'm also interested to know if there's any bridge between EPICS and CVI.
There's a vi for LabView that translates the PV (Process Variables) of EPICS into network variables, so I guess it could probably work with CVI as well.
11-07-2014 10:28 AM
Hey gdargaud,
I haven't been able to find any specific information about using the EPICS standards with CVI. However, as you mentioned, this is an old discussion, so you might have more luck creating a new forum post about this question to increase its visibility to the community.
Myriam
