‎05-19-2008 02:10 AM
‎05-20-2008 07:40 AM
‎05-20-2008 08:02 AM
Some of our systems use CVI 7.0 in a XP Embedded environment, with no known issues. No reason it should not be happy with a flash disc based system - this is down to the OS, not an application.
JR
‎05-20-2008 08:40 AM
‎05-23-2008 07:00 AM
CVI works well on XP embedded. Having said that, you can not tell the user of XP Embedded that your application will run. XP Embedded is using XP components to build an XP Embedded image that fit the requirements for a specific device. The components selected are not known to you. CVI may require components that are not included in the specific XP Embedded image. It is up to the XP Embedded image creator to implement the required components to allow your application to run using CVI runtime engine.
Jan
