LabWindows/CVI
Does CVI install the LabVIEW Run-Time Engine?
running the NI Update Service suggests to download a 226 MB patch for the LabVIEW 2012 Run-Time Engine... (all I installed knowingly was CVI2012)
--> How can I check if the computer has this engine installed, what is the file name to search for (and is it needed by CVI)?
Thanks!
Message 1 of 8
(5,341 Views)
1) You can use Measurement And Automation Explorer (MAX) to see the National Instruments Softwares installed:
MAX
2) Some CVI softwares use the Labview runtime.
By example, when you use the CVI Menu: Help / Find Examples... , you launch NIExampleFinder.exe which uses the labview runtime:
Process Explorer
3) When you install the NI-VISA library, the software C:\VXIPNP\WinNT\NIvisa\NIvisaic.exe is also installed. This utility is a Labview Software.
I think it's difficult to avoid the Labview runtime on a computer with NI softwares installed...
Message 2 of 8
(5,338 Views)
Thanks!
The computer in question has no measurement hardware, hence no MAX, VISA, device drivers are installed...
Message 3 of 8
(5,335 Views)
side note:
ahh, it happended again, it took me too long to edit the reply, I ran out of time, and everything has been discarded. When will NI/Lithium increase the time limit for edit operations... Smiley Frustrated
Thanks (and merci) for partially answering my question!
So searching the hard disk I found that indeed lvrt.dll is installed, in Program Files\National Instruments\Shared\LabVIEW Run-Time\2012
My remaining question(s):
- Do I really need this DLL or is it installed just as standard?
- This involves the question if I should download and install the 226 MB patch to fix a tiny (13 MB) DLL...?
Message 4 of 8
(5,329 Views)
Accepted by Wolfgang
Wolfgang,
The LabVIEW run-time engine is not necessary for any CVI program to run, but it is a dependency of some of the ADE tools, such as the Example Finder and the Distributed System Manager (used to configure network variables).
Luis
Message 5 of 8
(5,316 Views)
Thanks, Luis, for sharing the information Smiley Happy
Since I am using the Example Finder I seem to be dependent on LabVIEW...
I am not going to ask why the patch of a DLL is 20 times as large as the DLL to be replaced Smiley Wink
Message 6 of 8
(5,313 Views)
The patch of the DLL is large because the Labview runtime is made of many libraries (not only lvrt.dll): the size of the Directory: Program Files\National Instruments\Shared\LabVIEW Run-Time\2012 is > 80MB.
The Labview runtime is not tiny Smiley Wink
Message 7 of 8
(5,295 Views)
D'accord - I did not intend to offend any LabVIEW programmer...Smiley Happy
Message 8 of 8
(5,292 Views)
