LabWindows/CVI
Disabling timed callbacks
Hi! I created a timed callback using createTimedCallback which I would like to disable for some time. Is this possible somehow or do I need to go the roundabout way of creating a timer that I tie the callback to instead? I have several timed callbacks but I would like to disable only this one, and not the others.
Thanks!
(2,166 Views)
you can call SetCtrlAttribute for the timer with the attribute ATTR_ENABLED set to false. This will disable the timer
(2,150 Views)
Hi! Can you please elaborate? I didn't see the need to create a timer control, I simply called "createTimedCallback(myCallback, seconds_between_ticks);" and that seems to create a timer somewhere in the background, but I don't understand how to access it after its creation.
(2,145 Views)
Accepted by guybrush_threepwood
I have to admit that I don't know the function createTimedCallback...
(2,142 Views)
Oooops.
So sorry. I apparently have fewer braincells than usual today. Of course you don't. Apparently it's a user defined function in the program... ðŸ˜… Sorry for wasting your time and thank you for the explanation of how to disable timers!
Have a nice day!
(2,140 Views)
No problem, good luck with your project!
(2,136 Views)
