‎02-27-2008 02:34 AM
‎04-25-2008 01:37 PM
Evan Prothro
RF Systems Engineer | NI
‎05-26-2008 02:23 AM
‎05-27-2008 12:06 PM
‎05-28-2008 02:50 AM
‎11-26-2008 09:45 AM
I am also seeing this situation. My tester has a machine that he cannot see the "Done" button with using software I built that calls DirSelectPopup. He has another laptop that sees it fine, and It shows up fine on my machine.
Has anyone resolved this issue?
Judy
‎12-02-2008 02:52 PM
Hello Judy,
The issue that was reported here as causing problems for some computers has been fixed with the release of CVI 9.0. However, upon fixing the bug, a less serious but slightly more visible bug was introduced. If you are using CVI 9.0 and are unable to see the 'Done' button, you may just need to size the directory select popup to it's smallest width, and the button should then be there. This issue should be resolved in the maintenance release for CVI 9.0.
Sorry for the inconvenience,
NickB
‎12-03-2008 07:36 AM
Hi Nick,
Thanks for the info.
Judy
