LabWindows/CVI
Dimmed tab panels
if I dim a numeric control, it cannot be clicked on nor can it be selected.
If I dim a menu entry, I can not see its submenus and the menu cannot be selected.
However, if I dim a tab panel, I can select the tab panel, so that it is displayed. Somehow this looks inconsistent to me.
If this is by design, is there a way to have a tab panel disabled, so it can not be shown?
Using CVI2012, thanks!
(4,961 Views)
It does not seem inconsistent to me: a dimmed control or menu entry can actually be seen, even though it is not operable (that's why you cannot see submenus): the same happens with dimmed tab panels.
In case you want that a tab panel is not shown you can use SetTabPageAttribute (, , , ATTR_VISIBLE, 0);
(4,951 Views)
Hi Roberto,
Thanks for your comment and sorry for being sloppy: I want to see the panel tab, dimmed, but I don't want the user to be able to select it, so the user should not be able to see the tab panel contents (tab being analogous to a menu, the panel to the submenues...)
(4,947 Views)
I'm not aware of a built-in functionality that permits this behaviour. I suppose you could set a callback for the tab controls and handle EVENT_ACTIVE_TAB_CHANGE: I don't know if this event can be swallowed, but you can test it easily; in case it's not you can return to the previous active panel, which is received as eventData1 parameter.
(4,939 Views)
Accepted by Wolfgang
The current behavior is by design. The thinking is that even though a tab page is dimmed, you still might want to know what all is on that tab page.
You can use the callback to make a tab control behave the way you want it, but it does take a bit of programming. Here is an example of how to do it.
Hope this helps.
(4,923 Views)
Thank you all!
(4,918 Views)
