LabWindows/CVI
DeviceNet Multi Node Communication ?
Hi
Can some one please help.
I wrote a programe which reads and writes to a device using devicenet .
How do you read and write to multi nodes using devicenet ?
Thanks.
Help share your knowlegde
(4,564 Views)
Could you point me to the documentation which details the multi node communication please ?
(4,536 Views)
Hi Shako,
The best way to get started with using multi node communication is probably by checking out the EasyIOMultipleDevice.vi example in the example finder. It is located in the Hardware Input and Output >> DeviceNet folder, as shown below.
I hope that helps, let us know if you have any further questions.
Scott M.
(4,519 Views)
Accepted by topic author Shako
Thanks for the help.
I found in the documentation that when you call for an event you get the mac id and other information needed for multinodes.
(4,493 Views)
This is not what is in my example folder.  there are only two projects which aren't working.  How do i find these examples?  I am using LabVIEW 2010, have installed a PCI 8532 DeviceNet Board and wish to communicate with an MKS mass flow controller.
thanks,
chaz
(4,042 Views)
Hi chaz,
If you are using LabVIEW, you should post to the LabVIEW forum - this one is intended for CVI 😉
(4,038 Views)
