LabWindows/CVI
Debugging a Startup DLL on RT PXI
Dear Community;
We are in touch with NI support regarding this issue, but figure we would try the forum:
We are unable to debug a RT startup DLL on our PXI using LabWindow/CVI.
We setup the target type and target IP, but then when pressing the `Debug Project' button on the toolbar, we see an error message stating either:
  • `A different version of `startup.dll' is already running on the target' with the option to `Continue, Cancel or Reboot'.
    No matter what we select, nothing happens.  This happens if we install the dll in ni-rt\cvi on the target device.
  • `LabWindows/CVI cannot connect to the real-time target....'
Is this even the proper way to test ?
Find enclosed the project of the minimalist loop we are trying to run.
Thank you for any help;
Kindest regards.
Germain
(2,563 Views)
Accepted by topic author lechapelaing
I just found the solution reading this post:
https://forums.ni.com/t5/LabWindows-CVI/Remote-Debugging-with-CVI-2017/m-p/3914381#M81110
The firewall settings seem to have been the issue
Kind regards,
Germain
(2,554 Views)
