03-24-2016 07:14 AM
hi,
i am new to LabWindows. Can anyone explain me the procedure to test multiple DIO's Simultanuously using Daqmx in LabWindows. i have tried with example code but could not able to understand it. please help me to do this.
Thanks.
03-24-2016 08:02 AM
Can you explain better your requirements? "Test multiple DIOs" is nor really meaningful not knowing the scenario.
Knowing which board and how many boards are you intending to use and which functions you need to perform your tests (analog measurements / generation, digital measurements / drive, counters...) can help us help you better.
