03-27-2006 04:09 AM
I am using CVI 8.0 and must save data from a continuous measurement. The customer wants me to write it to Diadem format. So I had a look at the (new?) Diadem Conectivity library in CVI 8.
From the documentation
it seems to me, that this library only supports the new TDM format. But the
second parameter in the DDC_CreateFile function is named “File Type”. The documentation
is only speaking of TDM file type. What file types are supported by the
library? Only TDM? Or is also the older DAT type supported?
The second question is about continuous saving the date. I know, that the DAT file type supports a “block mode”, which is perfect to save data, when you do not know, how much data it will be. But when I look at the function, it seems to me that only the “channel mode” is supported. Is this right?
Stephan Gerhards
03-28-2006 03:06 AM
03-28-2006 02:05 PM
