LabWindows/CVI
Customize graph axis
With auto scale on, the X axis displays for example as below :
100, 250, 500, 750, 1000.
I would like to display the X axis as follow :
100, 500, 1000
Does any one know a way to do that ?
Bertrand
(3,165 Views)
You could use label strings: label strings in axis scale override automatic axis labelling with your own customized labels. They can be set either in the UIR editor if axis scale is not subject to change, or at runtime in case your scale changes during program life. Look in graph control help for a reference on label strings and how to set them programmatically.
Message Edited by Roberto Bozzolo on 07-16-2006 05:23 PM
(3,163 Views)
