LabWindows/CVI
Custom header file name
Simple Q: Is there a way to use a custom name for the automatically-generated uir header file (by default named the same as the .uir file)? If I try manually changing the name and reloading into project, a new header file is generated when compiling.
JP
(1,438 Views)
Accepted by topic author JakeP
As far as I know the association FileName.UIR <-> FileName.H is built into the UIR editor and cannot be changed.
(1,386 Views)
