LabWindows/CVI
Custom header file name
Simple Q: Is there a way to use a custom name for the automatically-generated uir header file (by default named the same as the .uir file)? If I try manually changing the name and reloading into project, a new header file is generated when compiling.
JP
(1,435 Views)
Accepted by JakeP
As far as I know the association FileName.UIR <-> FileName.H is built into the UIR editor and cannot be changed.
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
(1,383 Views)
