08-13-2008 09:46 AM
I am currently updating a CVI6.0 IVI class driver (DCPSU) in CVI8.5. The original version used the installer created in the DLL project to distribute this driver and then a WISE installer to configure LabVIEW to make it available to the user without the need to import it via the fp file.
I now have access to Create IVI Installer and have created a installer. The following questions have arisen though?
If anyone knows of an article that summaries any/all of the above I would appreciate it if they could post a link.
Thanks in advance.
08-20-2008 07:58 AM
Hi Kevin,
I shall post my reply to your email here so that others can also see the answers:
To answer your first question:
1) That does
seem a little on the small size for an installer but it really all
depends on what functions the customer is installing with the driver.
2)
If the MSI utility installs the files in the correct locations the IVI
driver will show up under IVI Drivers under Driver Sessions and
Software modules in MAX.
3) The VIs will show up on the IVI instrument I/O pallet.
4)
IVI class drivers do not implement a soft panel for testing but the
customer could create an exe to test if the hardware is working
correctly.
Dan - NIUK
