LabWindows/CVI
Convert double to IEEE 754(hex???) array
is there built-in function of Labwindows to convert double into array of IEEE 754 (or hex???, i am not so sure)
Like this:
Double                    Hex array
40                          00 00 42 20
40.5                        00 00 42 22
40.8                        33 33 42 23
Thank,
(PS: the hex arraies above are calc by Type-Casting in Labview)
(5,071 Views)
Sorry guys
i made a mistake between IEEE 754, hex, float, double
Here is the question:
I have a float-value (IEEE754) in labwindows, How can i convert it into unsigned int?
Would it be easier, if i use double instead of float?
(5,066 Views)
Accepted by Chocobombo
As far as I can tell, there is no built in function in LabWindows to do that, so you'll have to use what's available in C.  The two ways I know of is to use pointers to cast the pointer to the float value as a pointer to an unsigned int type and then retrieve the value as such:
	float f = 40.0f;
	unsigned int u;
	u = *((unsigned int *)&f);
 The other way is to use unions, which may be more convienent if you have to do this a lot.
union ex32
	float fval;
	unsigned int uval;
	float f = 40.0f;
	unsigned int u;
	union ex32 t;
	t.fval = f;
	u = t.uval;
(5,057 Views)
Thank tstanley, u saved my day 😄
(5,031 Views)
