LabWindows/CVI
Control Array Access Problem while loading panel on 2 Tabs
I am using LabWindows CVI 10.0. My intention is to programmatically disable a control array in a panel.
Problem:
       I am loading a panel with control array in TabControl pages -  Tab0 and Tab1.
Error occurs, While programmatically accessing through below functions.
GetCtrlArrayFromResourceID( Tab0_panel, CTRLARRAY) -  Able to get resource ID.
GetCtrlArrayFromResourceID( Tab1_panel, CTRLARRAY) - Not able to get resource ID.
Its giving error as Resource ID not found in UIR.
Error picture i have attached below for reference.
Please give some suggestions.Smiley Frustrated
Message 1 of 8
(4,271 Views)
Hi Zorro,
just a guess: tab panels are somewhat tricky, one of the usual stumbling blocks is the wrong handle...: did you use GetPanelHandleFromTabPage ( panel_handle, PANEL_TAB, 0, &tabpanel_0_handle ) etc.?
Message 2 of 8
(4,269 Views)
No i Used, GetCtrlArrayFromResourceID(tab0_panel, CTRLARRAY);
Because for the 1st loaded panel i am able to retrieve CTRLARRAY Ref.
But for 2nd one can't able to retrieve
Message 3 of 8
(4,266 Views)
Ok, if you didn't use it so far you should use it now Smiley Wink : If you are accessing controls on a tab panel you have to use the correct panel handle using the function GetPanelHandleFromTabPage, you can not simply use the constant defined in your UIR.
Have a look at the example TabExample.cws for an example of this function.
Message 4 of 8
(4,262 Views)
Hi Wolfgang,
Thanks for the reply.
But i am using Easy Tab Control.. Is it same as Tab?
Message 5 of 8
(4,260 Views)
Accepted by CVI_Zorro
Ah,... this you should have mentioned earlier...: No, it's not the same.
Moreover, EasyTab is outdated and superseded, so I suggest moving your UI to true tab panels
Message 6 of 8
(4,258 Views)
OK, Wolfgang. I will try New Tab Control...
Thanx for ur ideas.
Message 7 of 8
(4,256 Views)
My pleasure!
Message 8 of 8
(4,253 Views)
